| Fixin up my old ford | |
+3Motomow tracktor312 johnboggs21 7 posters |
| Subject: Fixin up my old ford Thu 03 Sep 2009, 11:12 pm | |
| Started bondoin up my pickup today. I have to say that bondo is some pretty neat stuff. Any advice on using it? I wire brushed the frame the other day and spray painted it black. Came across a few places in need of patching, but nothing major. Ill get pics if my camera decides it wants to work again. | |
| Subject: Re: Fixin up my old ford Fri 04 Sep 2009, 12:19 am | |
| use as little as possible replace as much metal as you can make sure to cut out any rust or else it will be back in no time... | |
| Subject: Re: Fixin up my old ford Thu 10 Sep 2009, 12:08 am | |
| yea johnny the more you use the more falls back out later on,thin as possible will make it stay on the truck. | |
| Subject: Re: Fixin up my old ford Tue 15 Sep 2009, 10:52 pm | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 9:26 am | |
| 2 words...replacement panels........
I know you are just trying to make it look better, and I am sure you know by next spring, most of that rust will be back......it really needs new metal....
I have had better luck with short strand fiberglass than bondo in these situations....seems to grip better. The trick is to get all the rust out 1st....of course, thats pretty much impossible. | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 10:11 am | |
| Yep replacement panels are fairly inexpensive cut out the old rust and weld in the new you will get years out of them .. | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 5:33 pm | |
| John doesn't want years, he wants months LOL.
Also, at this point it may be cheaper to buy a low miles, wrecked, parts truck, but that would cost more than john paid for his truck to begin with LOL.
Can anyone say "John will be driving a tin can on wheels" LOL | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 7:08 pm | |
| - tracktor312 wrote:
- Yep replacement panels are fairly inexpensive cut out the old rust and weld in the new you will get years out of them ..
While they are not replacement panels, i did cut out the old rusted metal, and welded in new. If anything itll keep snow out of the cab. | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 9:02 pm | |
| I just had to | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 9:49 pm | |
| Hey thats a good one! Why did you write it on a band-aid? |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 9:50 pm | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 10:15 pm | |
| Don't tell me another ford fan | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 10:56 pm | |
| Sorry man I got three of them in the driveway. |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 11:04 pm | |
| Subject: Re: Fixin up my old ford Wed 16 Sep 2009, 11:23 pm | |
| I got 3 of em on blocks lol jk | |
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 12:14 am | |
| whose movin to mexico for cheap labor? Oh Yeah FORD | |
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 10:38 am | |
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 11:38 am | |
| I would just patch it with the metal johnny and forget the bondo it will never hold for ya,patch it find some paint that matches as close as you can and live with it,you can make it look better but without replacing the panels you'll be doing a lot of work for nothing i'm afraid ......KW | |
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 6:16 pm | |
- I would just patch it with the metal johnny and forget the bondo it will never hold for ya,patch it find some paint that matches as close as you can and live with it,you can make it look better but without replacing the panels you'll be doing a lot of work for nothing i'm afraid ......KW
Well bondos cheap and I have LOTS of spare time. | |
ohmar99 Post Addict
Posts : 345 Join date : 2009-02-25 Age : 50 Location : ALTON, IL
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 6:35 pm | |
| thanks Johnny and JD, I got the old girl running again and riding like a rotten log wagon.
someone gave me some new cab lights for it but thats too much work. I do have a headache rack for it though | |
| Subject: Re: Fixin up my old ford Thu 17 Sep 2009, 7:23 pm | |
| - ohmar99 wrote:
- thanks Johnny and JD, I got the old girl running again and riding like a rotten log wagon.
someone gave me some new cab lights for it but thats too much work. I do have a headache rack for it though Good to hear ya got her runnin. What was wrong with it? | |
ohmar99 Post Addict
| Subject: Re: Fixin up my old ford Fri 18 Sep 2009, 10:34 am | |
| had fuel to the IP but not to the cylinders. the fuel shut off solonoid was clicking like it was working. I didnt want to pay for an IP so i pulled the FSS apart and found that it was all gummed up from sitting so much and even though the solonoid was working, the mechanical valve was stuck in the closed position. This was also causing my accellerator to stick open . Now she fires and smokes right up. had to order all my filters though, then I will start on the front end and suspension. | |
| Subject: Re: Fixin up my old ford Sun 20 Sep 2009, 10:54 pm | |
| well grandpa borrowed me a palm sander today, so i got some sandpaper from wally world to fit it. Should speed things up quite a bit. Im thinking ill replace the front drivers side fender. Im afraid its to far gone to repair. Ill probly just rob one off another truck in the junk yard if i can find one wiht a good fender. Also picked up some fuses today and got my CB workin again. | |
| Subject: Re: Fixin up my old ford | |
