| Subject: takin a fly wheel off Mon 22 Jun 2009, 6:39 pm | |
| Ok Larry i had trouble wit your diagram. So my parts motor that im gettin the fly wheel off of is gettin takin apart 1st so i know how the other motor is put together. Any info on an 8 HP briggs takin it apart of puttin it back together will be appreciated. | |
| Subject: Re: takin a fly wheel off Mon 22 Jun 2009, 7:29 pm | |
| ok i got the nut off i just need to know how to pull the fly wheel off now | |
| Subject: Re: takin a fly wheel off Mon 22 Jun 2009, 7:38 pm | |
| put a prybar or big screwdriver under the flywheel and pry while hitting the shaft with a ball peen hammer. A good sharp tap should do it, but be careful not to damage the threads if you need them. This usually gets em off. | |
| Subject: Re: takin a fly wheel off Mon 22 Jun 2009, 7:40 pm | |
| it says dont pry lol but i did lol ill try wat u said | |
| Subject: Re: takin a fly wheel off Mon 22 Jun 2009, 7:58 pm | |
| just dont ram ur prybar way up under neath the flywheel | |
| Subject: Re: takin a fly wheel off Mon 22 Jun 2009, 8:41 pm | |
| The idea is to give a bit of outward pressure on the flywheel, when you give it a good smack.....If the threads come right to the end of the crankshaft, I leave the nut on when hitting it, enough to cover the threads......Saves the threads. | |
| Subject: Re: takin a fly wheel off | |
