| Homelite????? | |
+2tracktor312 Jared Olson for SO IL 6 posters |
| Subject: Homelite????? Sun 25 Apr 2010, 11:33 am | |
| I'm going to go look at a LT16 Homelite tomarrow. I aint got a clue to what it is. Anybody know anything about Homelite mowers? All I know is it's 16 horse, big, blue and it's hydro. |
| Subject: Re: Homelite????? Sun 25 Apr 2010, 11:55 am | |
| - JD wrote:
- I'm going to go look at a LT16 Homelite tomarrow. I aint got a clue to what it is. Anybody know anything about Homelite mowers? All I know is it's 16 horse, big, blue and it's hydro.
Same as Simplicity. I think Simplicity made em. AC is in there somewhere 2 | |
| Subject: Re: Homelite????? Sun 25 Apr 2010, 12:18 pm | |
| COOL! I was told it runs and the kid that has it wants $100 for it. So I'm thinking I can get it for around $75...lol |
| Subject: Re: Homelite????? Sun 25 Apr 2010, 2:29 pm | |
| Yes alot were made by simplicity if its one they are great tractors I like the blue better than the simplicity orange if you get it we need pics ..... | |
| Subject: Re: Homelite????? Sun 25 Apr 2010, 11:34 pm | |
| Here's one that showed up at a local show last year. It was a '74 model T-10. I believe it had a Briggs. | |
| Subject: Re: Homelite????? Mon 26 Apr 2010, 10:38 pm | |
| Subject: Re: Homelite????? Mon 26 Apr 2010, 11:57 pm | |
| Yeah nice looks better than the simplicity I think looks like the pto for the deck is there the clutch up front is for the blower the lever under your left knee is for the deck I believe!! Also it should be a Briggs | |
| Subject: Re: Homelite????? Tue 27 Apr 2010, 3:53 am | |
| neat find - and a tractor you don't see every day | |
osenga
Posts : 61 Join date : 2009-03-14 Age : 47 Location : Grover Hill Ohio
| Subject: Re: Homelite????? Tue 27 Apr 2010, 9:41 pm | |
| Nice find I would have bought for 50 would fit in nice with my simplicitys and AC The front clutch is not there but on the BGB is there and the deck belt goes off that to run your deck . and if you are having rear end trouble try draining the fluid put new filter on and it take 3 Quarts to refill it and once they get so low they dont run worth %$#^ . ALL i have is simplicity/AC Need any other questions anwered email me @ simplicity_ac@yahoo.com | |
| Subject: Re: Homelite????? Tue 27 Apr 2010, 10:48 pm | |
| Thanks for heading me in the right direction on the clutch setup. I didnt have much time to look at it, I made sure the engine wasnt locked up, offered the kid $50 and ran. havent had time yet to look it over and see what engine it has. I was going off what he told me and he aint real smart. One thing you all can help me with is the right wheel hub and the lever on top of the hydro unit. The right wheel hub you can see in the pic and under the body on top of the rear end is a L shaped lever that pulls straight up. looks like it sets on top of a pair of valves. |
| Subject: Re: Homelite????? Wed 28 Apr 2010, 9:29 pm | |
| This is the lever over the two valves. Any ideas? |
| Subject: Re: Homelite????? Thu 29 Apr 2010, 8:40 am | |
| I believe you need to clean those valve up a little and get them to move they are for free wheeling the tractor if you need to push it they release the hydro so it will roll | |
| Subject: Re: Homelite????? Thu 29 Apr 2010, 6:11 pm | |
| - tracktor312 wrote:
- I believe you need to clean those valve up a little and get them to move they are for free wheeling the tractor if you need to push it they release the hydro so it will roll
ya notin like pushin a hydro lol | |
| Subject: Re: Homelite????? Thu 29 Apr 2010, 10:00 pm | |
| Kinda thought that was for free wheeling. You should of seen us loading it on the trailer with the rear wheels locked...Made me feel my age. |
| Subject: Re: Homelite????? Thu 29 Apr 2010, 11:31 pm | |
| Have you worked on her yet?? I always wanted the homelite. We have a winch on the trailer makes it easy even by myself. All tractors are winched on weather they run or not. | |
| Subject: Re: Homelite????? Fri 30 Apr 2010, 9:22 pm | |
- Have you worked on her yet?? I always wanted the homelite. We have a winch on the trailer makes it easy even by myself. All tractors are winched on weather they run or not.
Havent had time to touch it yet. I've been thinking about mounting a atv winch on the front of my trailer for a while now. After loading the homelite It's going to get mounted real quick. I did go out and turn over the engine by hand and I think the compression is a little on the low side. I was told it ran, but smoked a lil. Hope it dont smoke as bad as a walk behind I've seen on here...lol |
| Subject: Re: Homelite????? Fri 30 Apr 2010, 9:45 pm | |
Havent had time to touch it yet. I've been thinking about mounting a atv winch on the front of my trailer for a while now. After loading the homelite It's going to get mounted real quick. I did go out and turn over the engine by hand and I think the compression is a little on the low side. I was told it ran, but smoked a lil. Hope it dont smoke as bad as a walk behind I've seen on here...lol Concerning the ATV winch. Make sure ya get a good one. Grandpa had HF one that he mounted to a trailer, and we used it to pull a small dozer, about 800 lbs, onto it. The winch was rated for 1200 IIRC, and would only pull the damn thing about 4 inches before it would kick out. | |
| Subject: Re: Homelite????? Sat 01 May 2010, 10:36 am | |
| Thats OK its old enough to smoke if it wants most don't go that long and it willl still do the work of 3 others!!! | |
| Subject: Re: Homelite????? | |
| Homelite????? | |
