Oh but the tin can IS factory - - Folgers factory
It had a stack on it at one time but that rotted off, hence the can. The Kohler was already locked up when I bought it as the can wasn't always there.
This tractor has me baffled. The drive is the most homemade looking part. The belt off the crankshaft drives a 90 degree gearbox witha 140:1 reduction! That gearbox sits under the sloping dash. Power is then put to a small clutch with a hand lever [has black grip in pic] and on into a standard automotive looking three speed tranny. The shifter comes right out the top of the trans, which isn't unheard of but most auto trannys have shift linkage on the side. This is not the super small Borg Warner tranny used in Crosley cars and Power King tractors, its larger. The power is then chain drive to the rearend much like a Panzer garden tractor except it is geared back UP before the rearend. Apparently the 140:1 gearbox made gearing too low. The back of the trans has the big sprocket and the front of the differential has the small sprocket.
The rearend is standard looking Dana 20 but made narrow for this application. The brakes are hydraulic and that REALLY screams home built. The hubs are 4 bolt as you can see in the pic and the tires are 7.75X15 that were recapped for this application.
If it is homebrewed someone had a good size metal brake to bend the tinwork, which is too thick to be called sheetmetal. The front axle is solid inch and a half by two inch, overkill to say the least! The steering wheel is Chevy Corvair, but that may have been changed. The hood opened to put gas in but someone cut a very rough hole through the hood for access to the gas cap. Gas tank and starter/generator are missing. There is an assessory drive and implement lift such as for a mower deck, but I didn't get a deck with it. There is a cutout in the grille shell for clearance for the starter / generator that has a curved cut that is way too neat to be anything but factory. Actually, all the body work is very neat and doesn't look amateur in any way. There are no serial tags or numbers anywhere on the tractor.
Jared O, keen eye to catch the second Case in the pic!
