kriscrash4x4
Posts : 2 Join date : 2009-05-17
| Subject: Can somebody tell me about this lawnmower? Sun 17 May 2009, 10:51 am | |
| Can somebody tell me about this lawnmower? Its a motomower
Tractor, Model 0020 Type 100b Serial 11257
Engine, Model 147402 Type 015702 6604061
I do not know what the 6604061 number is, is was too rusty to read I hope i got it right | |
| Subject: Re: Can somebody tell me about this lawnmower? Sun 17 May 2009, 1:52 pm | |
| I don't know much about Motomowers myself, however we have at least a couple good Motomower guys on here that might be able produce the info you need. If I could make a suggestion it would be post a picture of the machine so we can all see it. I know you are new here so welcome to the forum, I will see if I cant give you a crash course in uploading pictures.
There are two buttons on the top row under the "subject" blank. One says "host an image" and the other just says "image" when you hover your cursor over it. Click "host an image" if you dont use an image hosting site like photobucket or myspace, if you do use an image hosting site click image. Just follow the directions in the window and click the button again to close the window. | |
| Subject: Re: Can somebody tell me about this lawnmower? Sun 17 May 2009, 2:30 pm | |
| Also, to help get this thread noticed more I am going to move it to General Discussion and leave it in this section as well, just have it in more places. | |
| Subject: Re: Can somebody tell me about this lawnmower? Sun 17 May 2009, 4:02 pm | |
| Welcome aboard! We sure would love to see some pictures! Does it look like the 1st Moto-Mower on this page? http://www.motomow.com/motomowers.htmlIf so, it is a model 6020, not 0020. I'm not aware of any tractors built by Moto-Mower with a model # 0020. Most of the garden tractors built in the mid 60's all have a model # starting with 6, like my 6024 and 6025. Based on the engine numbers that you provided, I'm guessing that it has a Briggs engine. The 3rd set of numbers are the code used to date the engine. The number 6604061 indicates that the engine was built on April 6th, 1966 I believe (someone correct me if I'm wrong). I do know for sure that the 1966 is right as the year is always indicated by the 1st 2 digits in the code. So, how does your Moto-Mower run? Do you have a deck or any other attachments with it? These tractors are not real common, but I've started to see more of them in recent years. Pictures of my 2 Moto-Mower's are located here: http://www.motomow.com/id218.html | |
kriscrash4x4
| Subject: Re: Can somebody tell me about this lawnmower? Sun 17 May 2009, 4:21 pm | |
| It must be a 6020 because i checked the page you posted and its the same i do not have pictures i have a deck for it but it dosent work its missing the idler/tension pulley. It does run but needs a carb kit real bad it leaks gas real bad. it is a B&S 6 1/2 motor. it hasent ran for a few years now the motor is almost wore right out but it purrs real good and still has power my dad bought it years ago and he gave it to me i dont know why i keep it around. it pops out of 3rd gear sometimes too. | |
| Subject: Re: Can somebody tell me about this lawnmower? | |
