| The Springfield is home. | |
FrankenCub
Posts : 12 Join date : 2009-09-28 Age : 48 Location : Whitney Point, NY
 | Subject: The Springfield is home. Fri 09 Oct 2009, 1:37 pm | |
| I brought home my new to me toy last night. Was hurtin too much to post last night.  I was quite surprised to find a serial tag intact .  The rest are hereWill get some more pics later. |
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 5:04 pm | |
| The serial tags are always intact it seems, what surprises me is when they are still bolted on the tractor. That tractor is nice, I don't have a 1962 Springfield in my collection, I do have the rest from 1961-1967, minus a 62 and 65. I have two 66s, might call one a 65 soon. I will get you a manual copied up and sent to you in the next couple weeks. Until then, just ask and I will find the answer.  |
FrankenCub
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 6:26 pm | |
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 9:43 pm | |
| Brendan, the drive belt goes around the footrest shaft and has a twist in it, a belt tensioner underneath keeps it off the mower mandrel (dead center of chassis). |
FrankenCub
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 9:48 pm | |
| Ok...so the foot rest rod comes off then reinstalled after the belt ? Huh....I must be missing a tentioner... |
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 10:00 pm | |
| Correct, the foot rest rod is bolted together with a coupling in the middle, seperate it and drop the clutch pulley in front of the tranny, install belt, reinstall the parts, and good to go. You are not missing the tensioner, I see it in the pictures, you just need the spring. I cant remember which way the belt twists off hand, but you aren't ready to install it yet. I will take a pic underneath my Springfield soon. By the way, the manual says to tip the tractor up on one side to service underneath. Not sure which side, I just go with most convenient at the moment, provided I can lift it.  |
FrankenCub
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 10:13 pm | |
| The tensioner in the pic is for the deck, I do see a bar sticking past the tensioner that looks like a pulley should be on it though.... |
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 10:27 pm | |
| Ok, now I see that, Had to open the picture. You are right, the stick is for a tensioner. It doesn't really need the tensioner, I had one running and driving and the belt just rubbed the mower mandrel, but the mower belt is off so it didnt really matter. If you hang on a couple days to a week or two I may have an extra tensioner bracket, whether it be off the springfield parts tractor i am redoing differently or with a decent sized lot of NOS springfield parts and pieces I am in the process of purchasing. |
 | Subject: Re: The Springfield is home. Fri 09 Oct 2009, 10:50 pm | |
- I do love those springfields,I think i've got 2 of my deere's sold I am definitly going to look for one in the spring
KW
Well I got the most Springfields / Toros right now, and no one will be able to top my group of em. By spring I plan to have at least 5, if not all 6 going and in a picture. One is a Gilson, but it has a lot of similarity, and seems logical, they took over Montgomery Wards' tractor line just about the time Toro got out, right after buying Springfield. |
FrankenCub
 | Subject: Re: The Springfield is home. Sat 10 Oct 2009, 2:50 am | |
| I actually have some tensioner's and pulleys that would work well. I was messing with the deck tonight, trying to free up the deck spindles. Well, it turned out the belts were so bad the spindles would not turn making me think they were froze up. Once I got the belts off the spindles turn fine, no slop or grinding feeling. It doesn't appear that it was used much at all. |
 | Subject: Re: The Springfield is home. Sat 10 Oct 2009, 6:54 am | |
| - FrankenCub wrote:
- I actually have some tensioner's and pulleys that would work well. I was messing with the deck tonight, trying to free up the deck spindles. Well, it turned out the belts were so bad the spindles would not turn making me think they were froze up. Once I got the belts off the spindles turn fine, no slop or grinding feeling. It doesn't appear that it was used much at all.
Good deal on the deck. The tensioner does something kinda special (in my opinion) and I can either sketch a diagram of it so you can make one yourself, or send you an extra if I have one. |
 | Subject: Re: The Springfield is home.  | |
