 My k321s blew
osenga
PostSubject: My k321s blew   Mon 03 Aug 2009, 4:31 pm
Ok guys I was out mowing my yard and my kohler decided to throw the balance gear the top one put a hole through my block> I had a buddy patch it up. And do I need the top gear or will I hurt anything
osenga
PostSubject: Re: My k321s blew   Mon 03 Aug 2009, 4:35 pm
OH ya I forgot to say that it did not hurt any other parts just that gear and the block but got the block fixed> So do I just put that pin back in the block to plug that hole that holds the gear the gear ended up in 3 peices
PostSubject: Re: My k321s blew   Mon 03 Aug 2009, 11:51 pm
Throw both balance gears away it will run fine without them..
osenga
PostSubject: Re: My k321s blew   Mon 03 Aug 2009, 11:56 pm
Ok thanks i was thinking the same. But I never had A kohler apart yet till now. and that was some weird gears half of it was big and the othe end small . do i jsut put the pins back in the holes then???
ohmar99
PostSubject: Re: My k321s blew   Tue 04 Aug 2009, 3:24 pm
Is that the one that I have often heard referred to as the grenade gear
osenga
PostSubject: I dont know that . But I was told now it wont hurt with out in there . I dont know much About the motor part yet but want to learn how to rebuild them . all I know that gear is1 1/2 thick on one half and a little more than a 3/8 on the other half .   Tue 04 Aug 2009, 4:27 pm
PostSubject: Re: My k321s blew   Tue 04 Aug 2009, 7:21 pm
Since I have 2 of these things in my Fords, I will ask......If they are not needed, why were they put in there?
My k321s blew
