Hi I Have a yard Man MTD It came home as a basket case I have it back together but the serial plate under the seat is gone and would like to know the year so I can lookit up at MTD.com The Tractor is a 18 hp Brigs Rec cowel engine, 50" cut Standard Transmission, Its Blue with a black deck and undercarage. It has a metal Hood Very Squaire, it has lover vents on top and on the sides. The head light lense is flat and squire and one piece. I tryied to get a pic posted here but wont load so email me and I will send a pic if you need it. If you have similar I would apreciate it if you could send me the serial and model # so I can find it. I also need help putting the deck on. There is a second pully mounted on a pully plate and has 2 springs then a rod that comes down from engage lever on dash. Cant figure out the springs and it dosent look righ the way I have it. any help here would be great ! Thanks Jeff
