| Subject: Measurements for a 12.5 HP briggs Mon 29 Jun 2009, 6:26 pm | |
| Subject: Re: Measurements for a 12.5 HP briggs Mon 29 Jun 2009, 6:42 pm | |
| nvm idk wat he wants to do he wants a new motor then he wants one rebuilt | |
| Subject: Re: Measurements for a 12.5 HP briggs Mon 29 Jun 2009, 8:38 pm | |
| Depends what you are putting it in place of......I put a 12.5 twin in place of a 12 hp single....Bolted right in, same shaft and everything.
The guy in that ad says go cart/tractor......That is a vertical shaft engine. Can't see how it would go in a go cart........just saying. | |
| Subject: Re: Measurements for a 12.5 HP briggs Mon 29 Jun 2009, 8:45 pm | |
| ive seen home made go carts wit a vertical in em | |
| Subject: Re: Measurements for a 12.5 HP briggs Mon 29 Jun 2009, 9:40 pm | |
| - poncho62 wrote:
- Depends what you are putting it in place of......I put a 12.5 twin in place of a 12 hp single....Bolted right in, same shaft and everything.
The guy in that ad says go cart/tractor......That is a vertical shaft engine. Can't see how it would go in a go cart........just saying. I thought it said that they used the mowers rearend too. They prolly swapped a smaller pulley on the transaxle and a bigger one on the motor, or something like that to make it go faster. | |
| Subject: Re: Measurements for a 12.5 HP briggs | |
