 Sears 10XL
wfullerton
PostSubject: Sears 10XL   Sat 13 Jun 2009, 12:30 pm
I have seem to have lost my post … So I will try this again Question
I have inherited a Sears 10XL that was once my grandfathers. It needs a lot of work, but I would like to restore it. Problem is Sears no longer caries parts and I do not know where to get parts. I need to replace the front clip/grill, and several other frame parts. Where can I get a rebuild kit/gaskets for the engine and carburetor Question Is there a way to make them Question I believe that the cutting deck is a Tecumseh and I have found multiple parts for that, however I still cannot find the pulley and the drive shaft. The engine seems to be a Craftsman, and I cannot find much on it. Other than it's cast iron¿ The garden tractor model number is 917.252040, if that helps.
Any help would be appreciated.
PostSubject: Re: Sears 10XL   Sat 13 Jun 2009, 1:56 pm
Hello the tractor was made by Roper for sears the engine should be a tecumsah alot of used parts are available on ebay the deck 917.252040 38" Rotary Mower for Custom Tractors there is a guy on ebay Rayf is a good guy ha can probably help you..
click on link below
http://stores.shop.ebay.com/SonShip-Salvage__W0QQ_armrsZ1
Sears 10XL
» 1966 sears craftsman build
» Sears Hot Rod Gasser Build
» I seem to be new here. 1969? Sears Suburban
» Sears Rat-Rod
» Pulley Swapped Sears Craftsman LTV 10 Driving
