| Mountin tire | |
+3Motomow poncho62 Jared Olson for SO IL 7 posters |
| Subject: Mountin tire Sat 13 Jun 2009, 10:04 pm | |
| Ive heard of it done and think its crazy but is anyone on here crazy enough to use ether to get a bead to seat? | |
| Subject: Re: Mountin tire Sat 13 Jun 2009, 11:39 pm | |
| I have seen the monster truck guys do it on TV........They spray something in there and light it....the expansion seats the tire. | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 12:18 am | |
| I've done it shoot ether (starting fluid) in the tire and light it,it's really a last resort thing tho,I would not want anyone to get hurt on what I said .I have done it is all I'm saying,KW | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 1:12 am | |
| Dont do it on a car tire or the like. If its something to be run at high speeds its not good. It weakens the tire and it could blow out. | |
shroonmagnet
Posts : 75 Join date : 2009-06-05 Age : 52 Location : Indiana USA
| Subject: Re: Mountin tire Sun 14 Jun 2009, 6:03 am | |
| Man Ive seen vids on you tube of people doing this,man looks kinda scary to me | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 10:46 am | |
| It's not a good idea guys.Here is the best method for me for small gardern tractors.I take a ratchet strap that you use to tie down tractors/motorcycles etc. I wrap it around the tire and ratchet it down fairly tight.I put just enough air in the tire to seal around the bead.Usually it will hold,I then remove the valve stem to let the air out and the tire will usually stay on the rim,pop off the strap and air the tire up.Sometimes this doesn't work meaning when you let the air out the tire comes back off the bead,if this happens you can put enough air in the tire to hold then release the strap.This is kind of the dangerous part to guys you have to be careful.DO NOT get a lot of pressure in the tire and then release the strap,the thing could pop off and really hurt you !!.I really don't like giving much advice on this subject i'd feel terrible if somone got hurt.This works for me everytime but it can be also dangerous,you really got to be careful,Always lay the tire down so the strap will not fly up.I've never really found the totally safe method to air up tires off the bead.The strap method to me is a lot safer in my opinion but still can be risky be careful if you do this,the totally safest method would be to take it to a tire shop they can figure out the best way to get the tire on and will probably only cost you a few buckjsKW | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 3:36 pm | |
| I just put a tube in them. Sure it costs a little extra but in the long run saves some frustration of leaks around the bead or valve stem. | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 3:43 pm | |
| Do they sell tubes for the aberage LT tire like what you would find on a murray? | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 3:58 pm | |
| Yes they do, Dad just tubes all the tires in the lawn tractor this year. | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 7:57 pm | |
| Excellent. It sure beats buyin a new tire. I need to get one or 2 for the murray. One of the rears leaks and one of the steer tires has a sloow leak. Bout how much do those run? | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 8:19 pm | |
| - johnboggs21 wrote:
- Excellent. It sure beats buyin a new tire. I need to get one or 2 for the murray. One of the rears leaks and one of the steer tires has a sloow leak. Bout how much do those run?
i think 10 each? | |
| Subject: Re: Mountin tire Sun 14 Jun 2009, 8:21 pm | |
| Cool. That definitly beats buying a new tire | |
ohmar99 Post Addict
Posts : 345 Join date : 2009-02-25 Age : 50 Location : ALTON, IL
| Subject: Re: Mountin tire Mon 15 Jun 2009, 11:09 am | |
- It's not a good idea guys.Here is the best method for me for small gardern tractors.I take a ratchet strap that you use to tie down tractors/motorcycles etc. I wrap it around the tire and ratchet it down fairly tight.I put just enough air in the tire to seal around the bead.Usually it will hold,I then remove the valve stem to let the air out and the tire will usually stay on the rim,pop off the strap and air the tire up.Sometimes this doesn't work meaning when you let the air out the tire comes back off the bead,if this happens you can put enough air in the tire to hold then release the strap.This is kind of the dangerous part to guys you have to be careful.DO NOT get a lot of pressure in the tire and then release the strap,the thing could pop off and really hurt you !!.I really don't like giving much advice on this subject i'd feel terrible if somone got hurt.This works for me everytime but it can be also dangerous,you really got to be careful,Always lay the tire down so the strap will not fly up.I've never really found the totally safe method to air up tires off the bead.The strap method to me is a lot safer in my opinion but still can be risky be careful if you do this,the totally safest method would be to take it to a tire shop they can figure out the best way to get the tire on and will probably only cost you a few buckjsKW
I am with you Ken, I have used the ratchet strap many times and it works well, usually my friends are quite bright enough to get the idea of why i need help sqeezing the tire in, self expanitory to me but I would not make a good teacher. | |
| Subject: Re: Mountin tire Mon 15 Jun 2009, 12:05 pm | |
| it definitly works for me ohmar,I do agree with the guys a tube is definitly safer but I will also say that if it's just a tire thats off the bead then i'll do the ratchet strap,I'm really not a cheap skate but buying a tube for a tire that has no problem other than being off the rim is kinda a waste of money to me plus I have to drive 10 miles to get a tube so i'll do the retchet strap lol..KW | |
| Subject: Re: Mountin tire | |
| Mountin tire | |
