 Bolens 2027
Go to page : Previous  1, 2
PostSubject: Re: Bolens 2027   Wed 29 Apr 2009, 11:36 am
poncho62 wrote:
Motomow wrote:
On those briggs poncho when they surge it's usually always the low idle speed screw,pop the air cleaner off adjust the top screw in or out a bit and i'll be it will stop Smile KW
Messed with the screws, but still surged.......Took it apart and cleaned, blew it all out....still did it.
There is a little screw that goes into the housing on top...It doesn't have a needle on the end, but has a little hole in the bottom. I turned it out 1/4 turn and that cured it. Only thing is, the screw, not being bottomed out is loose now and turns real easy. I put a drop of Locktite on the threads and put it back in..........This isn't the hi speed screw you were talking about, was it?
The low idle speed screw is on top poncho under the air cleaner,the high speed screw is underneath on the float bowl.You need to idle it down and adjust the low speed screw on top.this should stop the surge,idle it up to where it running pretty fast then adjust the fast idel on the float bowl this should get it smoothed out,turning the screw out far enough to where it is loose usually means a carb kit the parts are getting wore down.It's really important poncho that it's idling way down for the top screw and way up for the bottom fast idle screw this should get you dialed in : )
PostSubject: Re: Bolens 2027   Thu 30 Apr 2009, 4:30 pm
Ken...Here is pic of the carb i question......its a bit blurry......anyways, the idle screw and hi speed screw are circled in yellow....The one I circled in red is the one that I turned out a 1/2 turn or so to get it to run right.
Also, a couple of pics from the deck I am installing.........
PostSubject: Re: Bolens 2027   Fri 01 May 2009, 5:38 pm
Damn engine seized up on me today....Had it running a couple of times getting the deck belt right. All of a sudden, it wouldn't turn over, engine would stop in one spot. Took the head off and there's a big score in the wall and the edge of piston has aluminum jammed on the edge.......Pulled it apart, rings are all broke and seized in. Never had that happen before....maybe sat too long and corrosion got it????
Looks like I will just strip it for parts now...only $40 invested, not the end of the world.
PostSubject: Re: Bolens 2027   Mon 04 May 2009, 1:25 am
well hate to hear that poncho,thats a rare deal for those engines,if they are full of oil you cant hardly blow them up,ah well no use messing with the carb now,not trying to be funny again sorry buddy.KW
PostSubject: Re: Bolens 2027   Mon 04 May 2009, 9:25 am
I know what you mean...I have never blown one of them before.....It had fresh oil in it, but the piston and rings are wasted.........the little oil splasher dealie`was on there and looked like it was working....but it looks like there was no oil getting to the piston. Was running good.....shut it off and next time it wouldn't turn over....Just like that.......Hate when I can't figure why something happens
PostSubject: Re: Bolens 2027   Mon 04 May 2009, 11:33 am
your probably right about maybe it just sit around to long,what sucks is your kids may be disapointed they were probably looking forward to their own little mower,dad will have to find them a new one now,or shoot man another engine would be pretty cheap probably for that.
PostSubject: Re: Bolens 2027   Mon 04 May 2009, 8:39 pm
Yeah...will keep an eye peeled for an engine....or another mower....or another tractor.......LOL
ohmar99
PostSubject: Re: Bolens 2027   Tue 12 May 2009, 7:40 pm
PostSubject: Re: Bolens 2027   Tue 12 May 2009, 8:33 pm
A bit far for me....thanks anyways
ohmar99
PostSubject: Re: Bolens 2027   Wed 13 May 2009, 8:08 pm
a little high for having a messed up trans.
Bolens 2027
Page 2 of 2Go to page : Previous  1, 2
