 Panzer Build
4 posters
Go to page : 1, 2  Next
kent
kent
Panzer Build Empty
PostSubject: Panzer Build   Panzer Build Icon_minitimeSat 17 Sep 2011, 6:38 pm
New one. Its a Panzer. T70 8 Horse Briggs. I need to move the fuel tank back where it goes. Motor spins free. I will probably get it running before I do the tear down.
Panzer Build Dscf2612
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSat 17 Sep 2011, 6:46 pm
Panzer Build Dscf2613
Panzer Build Dscf2614
Panzer Build Dscf2615
Panzer Build Dscf2616
Panzer Build Dscf2617
Panzer Build Dscf2618
Panzer Build Dscf2620
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSat 17 Sep 2011, 9:07 pm
nice man,they must have had issues getting gas to the carb with that tank outside the hood,holy crap man hope you got a lot of time your gonna need it with all the stuff your buying lol.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 8:54 am
I need to slow down with the buying. I have a hard time turning down a good deal. The guy I bought this from want to trade me the AC that I was going to sell for $25.00 for a bunch of attachments for the panzer. On the Power King. If I bring it home, I will probably clean it up. fix the carb leak tune it up and sell it.
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 9:52 am
yea i use to say that kent,the power kings are pretty cool you get it running good you'll probably want to keep it,those things are just nice tractors and can do lot of things,i've pushed gravel/dirt with mine pulled and hauled engines with it pulled bushes and small tree's with it,they are just a horse man it';s hard to believe what they will do with a single cylinder engine on them.The bantam,power king and panzer have my vote all the rest would be sellers of course you may want a wheel horse in your collection most guy';s do nothing wrong with that either...
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 10:43 am
I like it!! keep pics coming throughout the teardown and build! I think the powerking will surprise you if you haven't had one before they are so much stronger than people believe.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 6:32 pm
I bought this as a non running tractor. The guy said it ran when he parked it. And he couldn't get it to run when he pulled it out of the barn. I just went out and checked the fuel tank. I was going to drain it and put fresh gas in it. It was dry so I put in some fuel and sea foam. It started on the first pull. It smokes when I put a load on the motor. But it ran good. No smoke when just running and not moving.
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 6:44 pm
Is it black smoke?? or blue if its black just running rich and the seafoam clearing it out !! if its blue then maybe the rings are a little worn.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 6:49 pm
It's blue. How much do you thank I am looking at in parts?
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 6:52 pm
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 6:58 pm
you could get lucky kent do a oil change right away and run it for a while it needs to be ran to see where your at.Drive it around some,just make sure your fluids are in it and nothing has water in it.I would not buy a thing until you get a chance to check it out really good.I never even think of rebuilds or parts unless they need it.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 7:01 pm
Doe's this one take sae 30 motor oil? It's a 8 horse briggs.
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 7:43 pm
yea straight 30 weight is fine even 10w30 works fine,kohler asks for 30w briggs 10w30 i've always used either or and never had problems.It may be the other way around larry probably knows for sure my memory sucks anymore...
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 7:46 pm
in my opinion gas is the main problem for the real old engines it burns hot and the old engines run ok but i think it';s hard on them where they are worn anyways.
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 9:22 pm
yeah straight 30 should be fine as KW said make sure to use it and get it up to temp a few times could be a sticky valve and may work itself out !!
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeSun 18 Sep 2011, 9:54 pm
I will do that. I won't start it again untill after I change the oil. Thank you so much for the advice. I love this site.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeMon 19 Sep 2011, 8:16 pm
How rare are speedex? I was offerd one today.
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeMon 19 Sep 2011, 8:36 pm
Around here they are pretty rare I have found a couple but to pricey for me. from all i have read they are good tough tractors
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 9:10 am
This one is complete. Doesn't run but motor spins free. $400.00
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 5:07 pm
they are rare for sure kent but $400 for a non runner wouldn't happen for me, $400 running sounds more fair and it would at least have to have a mower deck.It is definitly rare tho holy crap kent you have come accross everything i've been trying to find for over 25 years lol..
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 5:11 pm
Whats crazy is i've pretty much owned everything except for the stuff kent has bought.john deere,cub,bush hog,toro, wheel horse just about all of them.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 6:33 pm
On the panzer. I changed the oil. I ran it and it didn't smoke at first. then it started smoking. The tube that goes from the air filter to the carb has a hole in the bottom with a simple reed valve on it. the oil was pooring out from there, so it being sucked in to the intake. Could it be the valve stem seals? I will take a picture in a minute.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 6:44 pm
I put a red arrow where the oil is coming from.
kent
kent
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 6:45 pm
Panzer Build Dscf2627
Panzer Build Empty
PostSubject: Re: Panzer Build   Panzer Build Icon_minitimeTue 20 Sep 2011, 7:27 pm
Look and find the crankcase breather may be clogged and building pressure in the case
Panzer Build Empty
Panzer Build
Page 1 of 2Go to page : 1, 2  Next
» Murray build thread
» Panzer
» Panzer
» Bantam Build
» Panzer Hoard
