 wisconsin aen engine
bryson
PostSubject: wisconsin aen engine   Tue 07 Jun 2011, 6:10 pm
i have installed a 16 hrs winsconsin on my bolens husky 1050.ran great for a few years.now it will only rur for about 30 min before it pops once through the carb and quits.wont start again for a day then fires up and runs for anouther 30 min.engine is a 1cyl wisconson modle aen 16horse power with fairbanks morse magnito type x1b7e.i need info to diag.problem any help will be welcome.
PostSubject: Re: wisconsin aen engine   Tue 07 Jun 2011, 10:58 pm
Welcome to the forum.
Hopefully someone can help - not sure the issue. However, might try the basics: compression, fuel and fire.
Try a compression test cold and when it's not running. See how much it changes.
Could try spraying gas into the carb when it won't run and see if it's starving.
Is the spark good when it's hot - magneto could be shorting out when hot.
I'm writing this and just hit me - is the gas cap vent plugged? Try removing the gas cap when it won't run.
Good luck.
By the way, the specs on the Wisconsin web site indicates the AEN as 9.2HP.
» eml mini jumbo with kx 500 engine
» Shumaker Stage 2 Engine Cases 4.375 Bore
» 1940 Indian Chief engine Wanted
» Modified Clutch Cable Routing for 2-stroke engine
» wisconsin aen engine
