 k161 magneto?
PostSubject: k161 magneto?   Sat 05 Feb 2011, 7:10 pm
Got the ride-a-matic running. But it won't rev up.
While it's cranking you can hear the snap of a high-tension spark.
Went digging and found out that the coil is cracked and leaking a sticky red goo.
I started looking online - not luck. Anyone know where I might get one?
Or is my only real solution to go with a battery ignition?
PostSubject: Re: k161 magneto?   Sat 05 Feb 2011, 9:25 pm
I wonder if its too far gone to epoxy the crack. It is still working - just has spark jumping around in the crack instead of it all going to the plug. Be worth a try just to see if it would work and for how long. You'd have to completely fill any voids, not just seal over the crack. Question
PostSubject: Re: k161 magneto?   Sat 05 Feb 2011, 10:16 pm
It's knackered. Cracks running the whole length and in different directions. Pieces are falling off.
Looking online, it looks like similar coils are available - need to re-use the metal bar through the middle.
Wondering if there's a close enough match that will work?
PostSubject: Re: k161 magneto?   Sun 06 Feb 2011, 12:11 pm
PostSubject: Re: k161 magneto?   Tue 08 Feb 2011, 10:30 pm
Thanks 312 but that's for battery ignition - I can't get it to fit under the flywheel Wink.
I've found out the part # I need is: 230075 (engine spec suffix is an E):
http://www.partstree.com/parts/?lc=kohler_engines&mn=K161-28118+TRACTOR&dn=catalogs_13721
BUT - they are not to be had anywhere. I've found examples of the part for later model engines for about $100!
Question - should I be able to remove the coil from the bar? I've read that someone was able to replace the Kohler coil with a Tecumseh coil. Is there more than habit holding it on? I want to know before I use additional persuasion on it.
As for keeping it original - it's hidden under the flywheel. The spark will still look Kohler Smile.
PostSubject: Re: k161 magneto?   Sun 13 Mar 2011, 3:14 pm
She's alive!
I gave up looking for the correct magneto and bought a 12v resistor coil and condenser. Hooked them up today and the motor runs like a top after a minor carb adjustment.
Just need to figure out a place to mount the coil, a proper switch, finish the wiring and get a new coil wire.
Looks like the generator is working. battery was less then 12v before the motor was started and climbed up to 12.5v on a high idle.
I'm hoping to have it drive-able next weekend.
k161 magneto?
» Im having trouble starting my 14 hp I/C OHV motor.
» New craftsman.
» Im having trouble with my 12hp briggs starting.
» XP KILLER
» 10.5 brigs i/c
