 What Did I bring Home???
wh64s
PostSubject: What Did I bring Home???   Fri 21 Jan 2011, 3:01 pm
Hi Guys, I found an old Moto Mower but don't know exactly what I have. It came with a B&S 143302 motor. Could you tell me what model, year, etc it is? Also, it looks as if its hard to find parts for this machine, what would it cost (approx) to find the hood, fenders, belt guards, etc? Thanks, for your help, George
http://www.flickr.com/photos/56644506@N02/5231776942/in/photostream/
PostSubject: Re: What Did I bring Home???   Fri 21 Jan 2011, 4:00 pm
Sorry can't help you but welcome !! someone will be by to answer your questions. Looks like a great little project though!
PostSubject: Re: What Did I bring Home???   Sat 22 Jan 2011, 12:01 am
WELCOME!! The Briggs you have is somewhere between 5.75 horsepower and 6.0 horsepower. The reason I can't nail it down better is a heavier flywheel or a different carburator jet will change the power rating. The tractor manufacturer could spec anything they wanted from Briggs. With all the numbers a year could be found but you only supplied the model number. The model numbers break down like this:
1 \ ___ cubic inches of the engine
4 /
3 basic design of the engine
3 horizontal crankshaft
0 plain bearing ~~ translated: it has a bushing on the output crankshaft side instead of a ball bearing
2 rope start
That is a reasonablely rare machine so I feel your only chance to find the sheetmetal parts is to find another tractor that has what you need. It will not be easy to come by. It is likely that model did not have fenders from the factory and may have only had a belt cover leaving the frame rails exposed. They certainly do look better with fenders, and I wish you luck finding parts to complete the tractor! It definately deserves to be restored. Very Happy GOOD LUCK!!
PostSubject: Re: What Did I bring Home???   Sat 22 Jan 2011, 1:13 am
Welcome to the forum. Definitely another Moto-mower.
If they are still readable, there are 3 sets of numbers on the shroud - MODEL TYPE CODE.
The code should decode to YYMMDDn.
Looking closely - yours had the full-width body between the seat and steering wheel. I can see mounting bars. One vertical under the steering wheel holding a throttle lever and one pointing to the left just in front of the seat. I agree that body parts are going to be hard to find.
Here's a link with parts listings for a couple different models. I'm guessing the 6008 is a closer match.
http://www.motomow.com/motomowerpartsbook.html
Hope you don't mind - I linked directly to the picture:
wh64s
PostSubject: Re: What Did I bring Home???   Sat 22 Jan 2011, 6:46 pm
Thanks for the info guys. I just went down to look at the code on the Briggs and found it's "pre-code", it has a serial number instead. The type is 502855 and the serial number is 170655. I'll do a search, but if someone can date the engine, I'd appreciate the info. George
PostSubject: Re: What Did I bring Home???   Sat 22 Jan 2011, 10:28 pm
Is it possible where ever you got it from the would still have the sheet metal?
PostSubject: Re: What Did I bring Home???   Sun 23 Jan 2011, 12:06 am
I found the following site: http://www.asecc.com/data/briggs/data4.html
I have a late 60s Bolens 650 with what I believe is the original 6HP Briggs:
- model: 142301
- type: 502075
- code: 292066
Would this be a series 14 motor? If so, I can't make sense of the numbers.
wh64s
PostSubject: Re: What Did I bring Home???   Sun 23 Jan 2011, 5:08 pm
I found the same site (and a whole bunch more), but nothing would give any specific details. The only info I could find in its between a 5.75 and 6 hp motor built between 1959 and 1963 or 1965 depending on which site you believe. The info has to be out there but I can't seem to find it. Rolling Eyes
» home made lures
» Home made pike tackle
» Have A Great TWH To Give Away To A Good Home
» Welcome Home Viet Nam Vets Day, March 30 2011
» home made quick release steering wheel???
