 bolens 650
PostSubject: bolens 650   Sun 14 Nov 2010, 9:32 pm
I just brought this home - not sure if it works.
It's a lot rough - no deck, seat, and a tire that doesn't hold air.
There's some kind of goop on the carb - oozing out of the seam and on the bolts.
Briggs - model, type, code: 142301 502075 292066
Not sure how to break down the code - usually it's yymmddX - where X is the assembly line.
PostSubject: Re: bolens 650   Mon 15 Nov 2010, 7:17 am
Looks like a fun project
PostSubject: Re: bolens 650   Sat 27 Nov 2010, 12:50 am
Started looking into the mower to see what it needs:
- no compression - oops - sounds like an air compressor
Pulled the head off - blown head gasket. Two of the head bolts have heli-coils. The bolts won't torque down because they tried to re-use the stripped bolts and the heli-coils are sticking up above the block - not allowing the head to come all the way down.
Hoping new heli-coils and bolts will do the trick.
bolens 650
» Bolens "Mooselet"
» 74' bolens 1055/ G-10 (Rolling Thunder)
» bolens G-10/1055 front wheels
» Bolens FMC LT8 lifted tractor
» Bolens 1050 tubeframe snowplow build
