 case 224 hydriv electrical issues
simple_one57
simple_one57
PostSubject: case 224 hydriv electrical issues   Wed 16 Jun 2010, 2:03 pm
Hi all,been awhile since I have been on here,good to be back.I picked up an old case 224 hydriv.It does run and mows but has some electrical issues,looking for a wiring diagram.there is a panel below the steering wheel that has a box with two wires coming out of it and they are burnt,mower will not shut of with the key.any help on this matter would be appreciated
PostSubject: Re: case 224 hydriv electrical issues   Wed 16 Jun 2010, 5:24 pm
go here then under illustrated parts find your tractor by model and serial number and download the manual for free print or save to hard drive
http://www.ingersolltractors.com/
PostSubject: Re: case 224 hydriv electrical issues   Wed 16 Jun 2010, 5:25 pm
It souds like either a bad connection at the key switch or the wrong switch not killing power to the coil!!
simple_one57
simple_one57
PostSubject: Re: case 224 hydriv electrical issues   Mon 21 Jun 2010, 1:44 pm
thank you.I will check out the site and see what I can find
PostSubject: Re: case 224 hydriv electrical issues   Mon 21 Jun 2010, 7:58 pm
let us know how you make out !!
» Transmission & gear-case fill, drain and oil
» Fox STR alarms and reciever in presentation case.
» Pelican i1015 case
» KWA SR-12 Feeding issues
» Rotozip with attachments and case
