 Cleaning up the Cub
PostSubject: Cleaning up the Cub   Tue 11 May 2010, 4:52 pm
Well guys it looks a little better decided to just give it a quick cleanuptoday I made a grill insert and painted the grill shell front frame and starter /gen. Also sanded down the hood and hit it with primer . also wire wheeled the weight box primed and painted looks ok for a couple hours of playtime!!!!!
BEFORE!!![img][/img]
[img][/img]
AFTER!!!!!!!!!!!!
[img][/img]
[img][/img]
[img][/img]
PostSubject: Re: Cleaning up the Cub   Tue 11 May 2010, 8:27 pm
Got the hood done decided on appliance epoxy bisque looks good started to redo the decals (because I am to cheap to buy new ones) on the left side it was worn off got the black done buy its going to be tough to match the blue..
[img][/img]
[img][/img]
PostSubject: Re: Cleaning up the Cub   Wed 12 May 2010, 9:29 pm
Couple more days and it will look new... cheers It takes me a month to get that much done.
PostSubject: Re: Cleaning up the Cub   Wed 12 May 2010, 9:50 pm
only way to do one
PostSubject: Re: Cleaning up the Cub   Thu 13 May 2010, 2:58 pm
And a little more today
[img][/img]
[img][/img]
[img][/img]
PostSubject: Re: Cleaning up the Cub   Thu 13 May 2010, 9:45 pm
Ok, you've proved your point. lol!
PostSubject: Re: Cleaning up the Cub   Thu 13 May 2010, 11:18 pm
yeah I am happy with it but it is just a quicky clean up not a restore by any means. In a couple of hours you could make the homelite look great to!!!
PostSubject: Re: Cleaning up the Cub   Thu 13 May 2010, 11:28 pm
Gotta get it moving first. hate to paint it up then park it in the weeds. I've found just about every rearend that Simplicity made, but the one I need. Even found a pump. If I get her up and goin it'll get a nice coat of paint. Should be easy. The ole pig hasnt got a single dent in it.
Cleaning up the Cub
» Cleaning your gold,
» Cleaning gold
» Question on cleaning specimens- help required
» Cleaning carbs/ other parts with a parts washer?
» Cleaning Nugget
