 need help on 12.5hp briggs throttle linkage (MTD tractor)
2 posters
need help on 12.5hp briggs throttle linkage (MTD tractor) Empty
PostSubject: need help on 12.5hp briggs throttle linkage (MTD tractor)   need help on 12.5hp briggs throttle linkage (MTD tractor) Icon_minitimeThu 15 Apr 2010, 11:58 pm
I'm fixing up a ride-on mower.
I'm trying hard to figure out how the throttle linkage connects to the governor.
- need to confirm that at full throttle the throttle wire is shorter? (extends for slow)
- from the governor, the link to the carb is at the top and the spring connects in the middle?
Am I missing a piece? Cannot figure out how to draw tension to the right of the governor. The lever appears to pull in the wrong direction.
This is the inside side of the linkage.
The governor is towards the left and needs to be pulled to the left to accelerate.
need help on 12.5hp briggs throttle linkage (MTD tractor) Small-10
PostSubject: Re: need help on 12.5hp briggs throttle linkage (MTD tractor)   need help on 12.5hp briggs throttle linkage (MTD tractor) Icon_minitimeFri 16 Apr 2010, 8:36 am
I just went out and took a pic if the 10 hp B&S I have,......should be the same setup.....It is just a shot of the outside however, so not sure if it will help you at all. Looks to me that you are missing that lever going from that assembly up to the governor rod.
need help on 12.5hp briggs throttle linkage (MTD tractor) Bs_00210
PostSubject: Re: need help on 12.5hp briggs throttle linkage (MTD tractor)   need help on 12.5hp briggs throttle linkage (MTD tractor) Icon_minitimeSat 17 Apr 2010, 12:31 am
Thanks, but the throttle cable on yours comes in on top. On mine it's from the right.
My question - is there another part?
- the plate with the gizmo that rotates
- spring
- governor arm
PostSubject: Re: need help on 12.5hp briggs throttle linkage (MTD tractor)   need help on 12.5hp briggs throttle linkage (MTD tractor) Icon_minitimeMon 19 Apr 2010, 12:34 am
Was out today and found a couple examples to compare.
The problem is that the governor arm should be L-shaped. A short horizontal arm is broken or missing.
» throttle linkage
» Charlies home made tractor featured tractor of the week
» Measurements for a 12.5 HP briggs
» I dentifying an old tractor
» I can't find a head gasket for a Briggs.....
