osenga
Posts : 61 Join date : 2009-03-14 Age : 47 Location : Grover Hill Ohio
| Subject: need 916 help Mon 07 Dec 2009, 7:09 pm | |
| wanted to get my tire chains on my 916 it has the kohler in it . and when i went to move it . it will not start. it turns over strong and from the plug to the plug wire i have good spark to . and just cant figure out why it wont fire up. Is this the points condesor coil pack please help me before this white stuff shows up to where i will need it | |
| Subject: Re: need 916 help Mon 07 Dec 2009, 9:07 pm | |
| You need 3 things for an engine to run......spark, fuel , compression
You have spark from the coil.......Pull the plug and make sure it is firing at the tip of the plug...Better yet, get a new plug anyways.
If you have spark, spray a bit of gas down the carb and crank it. If it fires momentarily, you are not getting gas...Carb may be plugged......
That just leaves compression....do a compression test | |
| Subject: Re: need 916 help Mon 07 Dec 2009, 9:36 pm | |
| yeah do what poncho says then if that fail check to see if A valve is stuck seems pretty common on the kohlers I have had 3-4 of them this year I remove the head clean it good loosen the valve and they run great . | |
osenga
| Subject: Re: need 916 help Mon 07 Dec 2009, 9:45 pm | |
| well come to find out i had fresh and good fuel flow to carb and rebuilt carb about a mounth ago and this motor has 95 lbs of compression cold and took time and kept looking at the spark and decided it was not hot as i thought so i put a new plug in it and the same way. so I pulled the plug wire off the spark plug and out of the coil and found the half of the end that goes in the coil was rusted off so cleaned up that in the coil and put a new wire on it and . Once again she is running strong . on the first good snow we get i will post a pic of them out working . Thanks for your help and thanks alot | |
| Subject: Re: need 916 help | |
