 The Caterpillar turns jockey tractor
PostSubject: The Caterpillar turns jockey tractor   Tue 17 Nov 2009, 9:13 pm
In the past I have used the good old Caterpillar to move my heavily built homemade 6x10 trailer. Attempt one, easily spotted as a pass/fail method is still in place, along with the brand new, bolted together using leftover thick steel hitch LOL. The new hitch was fabbed last week and the top piece was added yesterday after the trial pull, which unlike the cheap aluminum bolt together angle iron, did not result in the trailer rolling away. lol!
How about pics. lol!
PostSubject: Re: The Caterpillar turns jockey tractor   Tue 17 Nov 2009, 11:38 pm
Nice seat mount! lol!
PostSubject: Re: The Caterpillar turns jockey tractor   Wed 18 Nov 2009, 12:22 am
Are those self tapping screws on that hinge?? PS you may want to put some thompsons water seal on the seat mount scratch those tires look awesome though not much clearance looks mean...........
PostSubject: Re: The Caterpillar turns jockey tractor   Wed 18 Nov 2009, 1:38 am
Yes, the shiny screws on the tractor end are self drilling/self tapping screws. They are holding up surprisingly well. Smile
I was goig to use them on the whole hinge but i had a couple heads break on the thick stuff so I drilled em out and used 1/4 in bolts on the hitch end.
The seat mount is just rigged for now, when I put the 444's new seat on the Craftsman seat will go on the Caterpillar, and I will put a small flatbed on the Caterpillar at that time also.
» My battery barely turns the starter. Could it be a bad a connection?
» Will Hydraulic brakes from ATVs and pit bikes work on a tractor?
» Whats your oldest tractor you owned?
» Don`t know what this little tractor is , but it is SweeeeT!
» How can i build a dullie tractor?
